22
This discussion topic has been answered Discussion topic: My SKY Q records in HD when I have selected SD, hence I can’t watch it . I have gone to my settings
Avatar for Flish1
This message was authored by: Flish1
Re: My SKY Q records in HD when I have selected SD, hence I can’t watch it . I have gone to my setti
Yes even if I select formats
Avatar for Flish1
Yes I have done and it's set to SD
This message was authored by: NellJ
Some channels only broadcast in HD. I find this frustrating as recorded programmes then take up too much memory! Some programmes I can record on the +1 channels which are broadcast in SD, but not all channels have the +1 option. I am disappointed that Discovery/History no longer have +1 options.
That setting is for downloads, not recordings.
It's hard drive space, not memory /pedant
You can get a LOT of HD recordings in even 1TB.
HD bitrates are much lower now than they used to be, recording in SD over HD doesn't save a great deal of memory.
@NellJ have you looked at the channels starting from 805 upwards as they are all SD channels, Sky History on 821 is in SD and 823 which is Discovery in SD so record these channels if you want SD
LG 49SJ 810 V UHD TV, Google Pixel 10 Pro XL mobile
Oi !
Answered - Go to Answer
