22 Mar 2024 05:58 PM
My SKY Q recordings won’t load and the SKY Q is getting very slow. I’ve switched it off. I’ve done a first step Reset, but still the same . I've checked and have 32% space left.
22 Mar 2024 06:14 PM - last edited: 22 Mar 2024 06:15 PM
Can you make new recordings @Jackie76 ?
If not
https://www.sky.com/help/articles/sky-q-hard-disk-error-messages
Don’t forget to keep your viewing card from the failed box if you order a replacement. Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box.
If you can make new recordings
22 Mar 2024 08:57 PM
Thanks for the info. It's made a little bit of difference and has recorded something and played back but it's still very slow.
22 Mar 2024 09:01 PM
Posted by a Superuser, not a Sky employee. Find out more22 Mar 2024 10:30 PM
I've done a complete disc drive reset and wiped all recordings off . I've downloaded a 1hr program and it's taken an hour to download. That's not normal ..
25 Mar 2024 06:19 PM
I had to get the engineer out in the end and they had to replace both the dish and box.
