Discussion topic: My Q mini box doesn't work if Sky Q box is on downstairs
This message was authored by: Catherine351
Everytime the sky Q box is on downstairs, the Mini box or WiFi doesn't work upstairs so have to turn the Q box off downstairs for everything to work upstairs. Fed up of it what's the point in 2 boxes If they won't work together.
Re: My Q mini box doesn't work if Sky Q box is on downstairs
Hi @Catherine351
Try a Reset Settings in the main Q box hidden menu.
Avatar for Catherine351
Oh wow. Thanks for that, I will try it and see what happens. Its driving me mad.
