Discussion topic: Mvmnt not allowing me to sign up
This message was authored by: Laura363
It keeps on coming up with an error code MYSKY_2306 and says something went wrong, we are working on this. But I have been trying for over a week
Re: Mvmnt not allowing me to sign up
@Laura363 Is It something you can use with Q? I thought it was only for those who used Sky Live on Glass.
Avatar for Laura363
It does mention sky Q online, but maybe i read it wrong. I will double check, thanks
This app is available on Sky Q.
That is a common error, often seen on other apps like Paramount +
Can you first try a restart of your Sky Q box;
  1. Press Standby on your Sky Q remote, then switch off or unplug at the mains and wait for the lights on your Sky Q box to turn off.
  2. Plug in and switch your Sky Q box back on at the mains.
  3. Wait for the on-screen instructions to disappear then press Home on your Sky Q remote.
If it's still not working after that, try a refresh of your Sky Q apps;
  1. Press Home on your Sky Q remote, then highlight Settings
  2. Press 0,0,1 and Select to access the Installer menu
  3. Select Apps then highlight Refresh all Apps on this box. You'll see a message that says, 'Your apps are being refreshed'.
  4. Press Dismiss to return to normal viewing.
The apps refresh can sometimes take up to 24 hours to complete fully.
