3
This discussion topic has been answered Discussion topic: Multiroom deals for 20 plus years customer.
This message was authored by: Henry+the+eigth
Hi everyone I have been with Sky for over 20 years now and as I am now on state pension I am trying to keep my costs down without losing my variety of watching. I have Sky Q and have a multiroom which is one mini box which is upstairs. If I wanted to add another would it be very expensive please? Many thanks. Kind Regards. H😎
Re: Multiroom deals for 20 plus years customer.
@Henry+the+eigth
Multiroom is a Sky+ term. The Sky Q equivalent is Multiscreen. There is likely to be an admin charge for another box but no extra on your Multiscreen subscription.
You can have a maximum of 4 mini boxes loaned to you by Sky. You can watch Sky content on two minis and the main box at the same time. You may be able to use a third mini box if the first one in use is being used for a streaming app ie: Netflix or DIsney+. It’s worth mentioning that UHD content can’t be viewed on a mini box.
Be aware the original 1TB (non-UHD) Sky Q box only allows one mini to be in use. To check if you have the non UHD 1TB box check in:-
If it shows as 32Cxxx then you have a non UHD 1TB that only supports 1 active mini box.
All 2TBs and the UHD/HDR 1TB permit two mini boxes.
▪️I AM NOT A SKY EMPLOYEE (not even undercover) ▪️
@Henry+the+eigth
This message was authored by: Invisiblename
As @Daniel0210  says, but please don't expect any special discounts because of the number years you've been with Sky!
I am just another Sky customer!
Avatar for Henry+the+eigth
Level 4 icon
Cheers Daniel much appreciated 😎
Answered - Go to Answer
