Discussion topic: Moving sky q main box to different room
This message was authored by: Pipg09
We have had some building work done which now means our living room will be moving. The sky box doesn't reach where we now want the tv what are our options with this? Will someone come out to extend or can we change box?
Re: Moving sky q main box to different room
Hi @Pipg09
Satellite cables are readily available if it is practical to extend the cables.
Failing that, provided the new location is near an external wall and there is a reasonable route to the satellite dish you could ask Sky if the dish cables can be relocated to the new position.
They would charge in the region of £65 to do this if it is possible.
Avatar for Pipg09
Thank you very helpful!
