3
This discussion topic has been answered Discussion topic: Moving my Sky equipment into my new extension
This message was authored by: Rahiel+shah
How do you go about moving my Broadband into my new extension?
This message was authored by: Jynxy Answer
Re: Moving my Sky equipment into my new extension
Hi, please try 0333 7591 018
Sky Superuser - If i have helped you please mark as solution to help others. Thanks
1x Sky Q Silver - 1x Sky Wifi Max Hub - SKY Fibre Ultrafast.
Do you mean move the master socket and hub? if so you would need to contact sky to arrange and pay for bt openreach to come out and relocate.
otherwise wifi should reach the extension from current location, or you can speak to sky about wifi extenders, if out of range.
Avatar for Rahiel+shah
@Jynxy  Thanks so much for your response, I want to contact Sky but don't seem to be able to get a phone number to call, do you know the number?
