6
This discussion topic has been answered Discussion topic: Moving home next week. Do I take Sky Q Box and Hub with me?
This message was authored by: marandiba
Moving home next week. Been sent two cables only. Do I take existing Sky Q Box and Hub to new address and set up myself?
Re: Moving home next week. Do I take Sky Q Box and Hub with me?
@marandiba
You take the hub, and Sky Q box(es) with you. Have you arranged a Sky Home Move?
https://www.sky.com/moving-home
@marandiba
Avatar for marandiba
Yes. It's all booked in but was vague about taking existing equipment. There's an engineer booked the day after move but I think a seperate note said it was down to me to hook everything up. OK will take Sky Q box and Hub and connect up when I get there. Thank you.
@marandiba
The Sky Home Move would involve a Sky engineer attending your new address which will definitely be required if there is no dish there or the dish was used for Sky+ by the previous occupants.
The existing occupants have Sky. I don't think there is a dish there so I imagine it's via cable. I'll assume the engineer visit goes ahead anyway. Thanks again.
Usually Q requires an individual dish.  However, there are some fibre distribution systems on some housing estates.
Thanks for the info
