Discussion topic: Moving equipment round my home
This message was authored by: Meme231715
Please can someone tell me if I can buy a lead that will make my sky box reach the other end of my front room
Re: Moving equipment round my home
@Meme231715
Typically that will be a twin satellite coaxial cable extension kit, widely available online in assorted lengths.
Avatar for Meme231715
Will I need 2 as I have sky q?
This message was authored by: Dallen9798
@Meme231715
Check the back of your Q Box, you may only have one or two coax inputs, just buy the extension based of what you already have
My views are my own and I will assist where possible.
Sky Q 2TB UHD, 2X Mini Box, Sky BB UF1, Booster 4
I am just a customer, If I've got something wrong feel free to tell me, If I've something right mark it as an answer
@Meme231715
Q typically uses two satellite feed cables when supplied from an individual dish.  One cable would usually be from a communal system in flats.
This message was authored by: Destamona81
Hi this is exactly the help I was looking for as I want to move my TV from one side of the living room the other. The Internet Router is also connected to the Sky Q box so is it the same principle of just buying an extension?
Q would normally connect via wireless - unless you have the Q box connected via Ethernet cable?
If so, you can buy longer ones.
