Discussion topic: Moving equipment round my home
Message posted on 17 Apr 2023 02:36 PM
Please can someone tell me if I can buy a lead that will make my sky box reach the other end of my front room
Message posted on 17 Apr 2023 02:42 PM - last edited: 17 Apr 2023 02:42 PM
Re: Moving equipment round my home
Typically that will be a twin satellite coaxial cable extension kit, widely available online in assorted lengths.
Message posted on 17 Apr 2023 02:43 PM
Will I need 2 as I have sky q?
Message posted on 17 Apr 2023 02:44 PM
Check the back of your Q Box, you may only have one or two coax inputs, just buy the extension based of what you already have
My views are my own and I will assist where possible.
Sky Q 2TB UHD, 2X Mini Box, Sky BB UF1, Booster 4
I am just a customer, If I've got something wrong feel free to tell me, If I've something right mark it as an answer
Message posted on 17 Apr 2023 02:57 PM - last edited: 17 Apr 2023 02:57 PM
Q typically uses two satellite feed cables when supplied from an individual dish. One cable would usually be from a communal system in flats.
Message posted on 20 Nov 2025 04:51 PM
Hi this is exactly the help I was looking for as I want to move my TV from one side of the living room the other. The Internet Router is also connected to the Sky Q box so is it the same principle of just buying an extension?
Message posted on 20 Nov 2025 04:59 PM
@Destamona81 wrote:The Internet Router is also connected to the Sky Q box so is it the same principle of just buying an extension?
Q would normally connect via wireless - unless you have the Q box connected via Ethernet cable?
If so, you can buy longer ones.
