5
This discussion topic has been answered Discussion topic: Moving Sky Q to block of flats
This message was authored by: Afrochap
Hello,
I have just moved and have Sky Q. However, the new property only have 1 satellite output.
1. Is it possible to have Sky Q at thr new Ddtess
2. Of ap how does work and what do I need to do?
This message was authored by: nigea99 Answer
Re: Moving Sky Q to block of flats
hi @Afrochap
As you mow have a communal feed you will need to check/change the LNB type to SCR - this is in an engineer's menu
To access it :
press Home
Scroll to Settings - but do not press enter/select at this point
Press 0 0 1 in sequence followed by  the Enter/ select button
you should now get the engineer's menu
Select the LNB Type & set to SCR if necessary
After changing the LNB type power down your SKY Q box and restart it for the change to come into effect
Edit please note however, it is quite possible (if not likely) that your feed is not SKY Q compatible and may need an 'adapter' to be fitted by SKY
Hi @Afrochap   If you used the Sky Move procedure, all of this would have been done for you.
https://www.sky.com/moving-home
@Afrochap wrote:
Hello,
@Afrochap sounds like you have moved into a property with a communual dish ?
If so you will need a Sky MDU engineer to come out to set you up
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
hi @Afrochap
To access it :
press Home
Avatar for Afrochap
@nigea99 Much thanks. I've tried this but no joy.
Avatar for Afrochap
I think so too but getting Sky on the phone is a pain. Chatting is impossible as it's just a bot.
I think they need to do better
