Discussion topic: Moving Netflix to my Sky Q?
This message was authored by: Hammer1
I have a Sky Q box and account that includes Netflix, however I also have a Netflix account that has 4 profiles on it for different family members in the same house.
I pay £17.99 to Netflix each month but understand I can get it a lot cheaper if I just view it through Sky.
How do I go about doing this and moving all 4 profiles as I'm getting conflicting info? Thanks
Re: Moving Netflix to my Sky Q?
@Hammer1
It's a little bit cheaper through Sky, because a current £17.99 monthly payment must be Netflix Premium and that means Sky Ultimate TV needs an add-on upgrade to the bundled Netflix Standard with Adverts.
Signing into the Netflix app on a Sky platform (Q, Glass or Stream) generates the instruction for Netflix to shift billing to the Sky account.
Note that the bundled Netflix doesn't have the additional household feature.
Hi @Hammer1
If you log into Netflix on Sky using your existing Netflix details then this will notify Netflix and they will cease billing.
Your profiles will transfer.
hi @Hammer1
If you are already paying for Netflix via SKY then the increase is not as much  but it is still cheaper via SK.
As the others have said if you log in to Netflix on your SKY box it should transfer your accout & profiles accross
See
https://www.sky.com/help/articles/netflix-faqs & follow the Help Guide Link
From Mid December last year you need Boost options  to get to other levels  :
Netflix  (Base level) is the With Ads service  - 2 Screens in HD (list cost £4) - which is what you are likely to have
Boost to Netflix Standard - 2 Screens in HD Ad free  (list price an additional £6  thus £10 in total for Netflix)
Boost to Netflix Premium - 4 Screens  up to UHD/HDR  (list price an additional £11 thus £15 in total for Netflix)  - you will need to get to the same level as you are currently paying direct
P.S. When you pay via SKY, you still cannot, currently, add the 'extra member' add on for use by family members not in your physical household that is available for those paying directly to Netflix
