Discussion topic: Move skyQ box from loft to new extension.
This message was authored by: Jacky+seagull
Weve had an extension built and the sky Q box and cable are currently in the loft. We want to move the skyQ into the new lounge. How can i get this done?
This message was authored by: Padam_Padam
Re: Move skyQ box from loft to new extension.
You can either pay an independent satellite installer to re-reroute the cabling to your specification or Sky will possibly do it for their standard £65 engineer visit fee. Be aware that they will probably just run new cabling from the dish, down the outside of your house, drill a hole in the wall of the new extension and feed the cabling through it. It won't necessarily be pretty.
If you're handy with DIY you can always just buy satellite extension cables and route the cables yourself, either internally or externally.
