Discussion topic: Miniboxes not working showing connected but not connected to this box and email not working ' techni
Message posted on 20 Jun 2023 08:35 PM
Message posted on 20 Jun 2023 08:41 PM
Re: Miniboxes not working showing connected but not connected to this box and email not working ' te
Hi @matty7891
Regarding the mini boxes not working:-
First try rebooting the main Q box and then when this is completely back up and running reboot the minis
Reboot the mini as above.
If the mini still does not connect try a Network Reset on the minis (start with the one nearest to the main Q box)
You will be asked to press the WPS button on the main Q box (not the mini).
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box.
Always try to WPS with the nearest connected Q device.
