Discussion topic: Minibox tv listings display in enlarged font and wrong colours
This message was authored by: AlunAndrews
I have tried toggling the accessibility settings without success
Re: Minibox tv listings display in enlarged font and wrong colours
You don't say which Accessibility settings you have toggled @AlunAndrews
Was it Screen magnifier in the mini box ?
Avatar for AlunAndrews
Yes it was
It shows as black on white enlarged.
The screen magnifier is set to off.
changing to on and back to off makes no difference. It is just one of my mini boxes doing it.
 Hi @AlunAndrews
Did you also try the High contrast settings in the mini box Accessibility?
No it is set to off. I'll try on and off now.
Turned both to on which made it bigger again.
Turning both off returned to previous wrong size and format.
