2
This discussion topic has been answered Discussion topic: Minibox not displaying pin prompt
This message was authored by: Emmyc109
I have an issue with newly delivered SkyQ mini box. Set up complete and can select all channels but if programme needs a pin input to view I just get a blank blue screen, no pin prompt. Works ok on main box.
I have retset pin and no change, also tried going to parental controls on mini box, here I get the pin prompt but justs sits there when I enter the pin, on main box goes straight to sub-menu as soon as 4th digit entered.
Re: Minibox not displaying pin prompt
Hi @Emmyc109
Reboot the mini as above.
Failing this try a Reset Settings  in the mini box hidden menu.
If you cannot switch the mini box on with the remote after the Reset press the Standby button (Amber led) on the front of the mini  box.
Hi @Emmyc109
Avatar for Emmyc109
@oldfella,
Many thanks, that has fixed it. 🙂
