Discussion topic: Minibox not connecting to the internet but is connected to the SkyQ box
This message was authored by: Coatesy
 the settings app says my minibox is not connected to the internet but is connected to the Qbox. I have tried resetting the network connection but keep getting the message that its not connected
Re: Minibox not connecting to the internet but is connected to the SkyQ box
Have you tried rebooting your main Sky Q box ?
Hi @Coatesy
Reboot the mini as above.
