Discussion topic: Minibox is not starting up after being unplugged when it says press the house icon ,nothing happens.
This message was authored by: Mike1520
Minibox not starting after being unplugged. When it says press home button nothing happens.
Re: Minibox is not starting up after being unplugged when it says press the house icon ,nothing happ
Hi @Mike1520
Have you tried pressing the Standby button (Amber led) on the front of the mini box.
If this turns the mini box on
Try completly resetting your mini Bluetooth remote.
Then make sure that you are pointing your remote at the mini box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
Avatar for Mike1520
Thanks Oldfella.
