Discussion topic: Minibox does not act as a wifi booster after install of skt max router
Message posted on 13 Nov 2024 03:57 PM
I received a sky max router today and after installation my miniboxes do not boost the WiFi signal. The miniboxes are working fine otherwise.
Message posted on 13 Nov 2024 04:01 PM - last edited: 13 Nov 2024 04:50 PM
Re: Minibox does not act as a wifi booster after install of skt max router
Hi @PH1971
As far as I understand it Sky Max routers work like 3rd Party routers. If this is correct they will not act as Hotspots.
Check the following link and see if you have the option to set hotspots.
Message posted on 13 Nov 2024 05:48 PM
Thank you, turning on the hotspots worked a treat. Sky should include this in the setup instructions, it would save lots of time.
Thanks again.
