Discussion topic: Minibox disconnecting from sky q
Message posted on 01 Jul 2024 09:23 PM
Hi, I purchased a new Sony Bravia and since connecting up as per my previous set up, every morning I get an mr102 error. This necessitates setting up as if new WiFi connection. I have a devialet sound box and noticed that previously I could turn off the tv and mini box using the sky remote, now this only turns off the mini box and I have to turn the tv off with the tv remote.
I have plugged the pink lead coming out from the back of the sound box into the HDMI IN port on the tv the same as it was on my previous tv, would this be correct? And also connected the optical cable.
TIA for anything stupid I am missing!
Message posted on 02 Jul 2024 09:52 AM
Re: Minibox disconnecting from sky q
Hi there @Saschagsd, I’ve escalated your post to our Community Messaging team who will invite you to a private chat shortly and help you with this.
Message posted on 04 Jul 2024 08:50 AM
We are still looking to help you @Saschagsd . If you need our support let us know and we can re-escalate to our chat team. Your invite has been closed now. Thanks
Lisa - Sky Tech Team Expert
Message posted on 13 Oct 2024 07:15 AM
Have you checked in settings whether your main box is set to Active rather than Eco? To check, go to settings, select setup, then select preferences then change Eco to Active. This problem usually happens in the early hours of the morning. Eco is designed to save you money by switching off the main Skybox.
