Discussion topic: Mini q box frozen for hours
Message posted on 12 Aug 2024 09:53 PM
Mini q box frozen on accessibility on sky Q message stuck on settings
Message posted on 12 Aug 2024 09:59 PM
Re: Mini q box frozen for hours
Pull the power connection on the main Q box, replace this, let it fully reboot and then do the same on the Mini box.
Message posted on 13 Aug 2024 10:14 AM
@Ashtonstreet try the following
Press & hold 4 & 6 together to reset the remote to IR only and then see if you can dismiss the message
the remote must have line of sight to the box for this.
then afterwwards press & hold 1 & 3 to re-pair the remote
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
