Discussion topic: Mini boxes won’t stay connected to internet and keep needing resetting
This message was authored by: evertonrees
Hi my mini boxes keep disconnecting from the sky a main box and internet
read many of forums and reset steps taking out many times
Avatar for evertonrees
Re: Mini boxes won’t stay connected to internet and keep needing resetting
Is there a permanent fix to this solution as it's really starting to do my head in and I'm not getting anywhere
Have you been correctly through the following @evertonrees .
Reboot the minis as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router if on Sky Broadband or previously connected mini).
Hi I have done all these steps many many times.
reconnects every time but doesn't hold connection for very long
Looks like you need a Q WiFi booster @evertonrees
Why would I need one of these after it has worked ok for years
only in the last 8 months it's been bad.
thought it could be a software update that sky has done or they don't like you using a third party broadband provider
