This discussion topic has been answered Discussion topic: Mini boxes not working since I’ve changed to full fibre broadband
Message posted on 14 May 2024 04:08 PM
They are not connecting to my broadband or my main sky q box. So the first issue is, how do I get them all back on line and working?
second issue is that one of the mini boxes won't connect to sky q remote. I've tried reactivating the remote by pressing 7 and 9 but the remote does not flash red. Because of this I can't progress further because I can't get into settings
Help!
Message posted on 14 May 2024 04:36 PM - last edited: 14 May 2024 04:40 PM
@white-cross wrote:
I should add that, for various reasons, I changed my network name at the same time. The sky q main box is working perfectly, it's just the mini boxes
Hi @white-cross
First try resetting your broadband router.
Once the main Q box is back up and running reboot the minis. Start with one neares to your Q box.
To reboot press Standby on your mini remote (if the box responds to the remote), and then switch off and unplug at the mains.
Wait at least 30 secs and then Plug back in and switch your mini box back on at the mains.
Wait for the on screen instructions to disappear and the front led to turn Amber. Then wait for 30 secs before you press Home on your mini remote or if this is not working press the standby button on the front of the Q box (Amber led)
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router if on Sky Broadband or previously connected mini).
If you cannot get one of the mini remotes working try pairing the other mini remote to the mini with issues.
Message posted on 14 May 2024 04:18 PM
Re: Mini boxes not working since I’ve changed to full fibre broadband
Hi @white-cross
Message posted on 14 May 2024 07:08 PM
Hi @oldfella
Would the procedure you describe reset the router to factory settings? If so, that's something I'd be very unhappy to do
Message posted on 14 May 2024 07:41 PM
@white-cross wrote:
Hi @oldfella
No @white-cross
Its just a reboot
Message posted on 16 May 2024 02:57 PM
Hi @oldfella
Just as I feared, I'm afraid, the system reset to factory settings, and everything crashed including my printer, hive heating and Alexa. Anyway all back up and running now
Good news is 3 of my mini boxes are now up and running. Thanks a lot
The fourth one still won't connect to the internet. I get stuck on a screen asking me the first of three questions and I can't move on because the remote is not connecting to the mini box. I've tried pressing 7 and 9 then 1 and 3. But the remote never flashes red. If I could re establish connection, I think I could get it up and running
id be grateful for any hints!
Message posted on 16 May 2024 04:48 PM - last edited: 16 May 2024 05:02 PM
@white-cross wrote:
Hi @oldfella
Hi @white-cross
You just need to press and hold 7 & 9 first (don't continue with 1 & 3 at this stage).
This will set the remote to infrared mode which will control all Q boxes in line of sight.
Of the remote led does not flash four times when you press and hold 7 & 9 then it has low battery or is faulty. If this is the case you could do the same procedure above with anther mini remote.
Once you get the remote into infrared mode make sure that you are pointing it at the mini and you should be able to move on with the setup.
Any remotes you reset to infrared will need pairing again once the boxes are running.
Message posted on 16 May 2024 05:12 PM
Hi @oldfella
yeah, the only problem with that is that I've tried two remotes and neither of them flash red. Changed batteries. No difference
Message posted on 16 May 2024 05:43 PM - last edited: 16 May 2024 05:44 PM
@white-cross wrote:
Hi @oldfella
Hi @white-cross
Try the other remotes. If the LED on the remote does not flash four times when you press and hold 7 & 9 together then there is an issue with the remote.
Edit
I assume they are Bluetooth remotes with voice control
Message posted on 17 May 2024 03:38 PM
Hi @oldfella
Successful at last. Phew! The third remote I tried worked. Luckily it was a spare one so I was able to re-pair it with that mini box and the TV. I still find it difficult to believe 2 remotes were faulty, but there you go! For various reasons I have several spares!
Thanks so much for your patience and help
Message posted on 07 Oct 2025 10:13 AM
Thanks for the advice! After rebooting everything multiple times it was the remote, holding down the 7 & 9 worked!
