Discussion topic: Mini boxes not working no internet not working on my tv
Message posted on 28 Jul 2024 08:58 PM
Mini boxes not working I have 2. No internet on the main box but have internet in the house
Message posted on 28 Jul 2024 09:11 PM
Re: Mini boxes not working no internet not working on my tv
Hi @Gemma124
Start by trying to get the main Q box connected.
