Discussion topic: Mini box won’t work message says connecting to your sky q box but it doesn’t
Message posted on 29 Nov 2023 09:14 PM
My main box works fine but mini box says it's connecting to sky q box but it doesn't. I've turned it on and off at the switch and it comes on briefly but then stops and message comes back. I've never had this particular issue before
Message posted on 29 Nov 2023 09:36 PM
Re: Mini box won’t work message says connecting to your sky q box but it doesn’t
Hi @Peggy24
Reboot the mini as above.
Message posted on 01 Dec 2023 08:26 AM
Thank you. I had to get Sky to sort it out in the end. But it's working now. Thanks for your advice
