Discussion topic: Mini box will not switch on , light remains orange, has only just stopped working and are unable to
This message was authored by: Jayjacmax
Mini box used to work upstairs but now light remains on orange and unable to get it to connect to tv
Re: Mini box will not switch on , light remains orange, has only just stopped working and are unable
Hi @Jayjacmax
Have you tried switching the mini on using the Standby button on the front right of the mini (the Amber led)?
If this turns the mini on
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
This message was authored by: Louise113
Hi my mini has only been in maybe two weeks,
the light is orange it's completely not responding I have tried the 7&9 and 1&3 there is no flashing at all it's just orange. I have turned it on and off, I have pressed the reset on the back. Still no joy
the box down stairs is working fine
This message was authored by: Willow14
My sky mini upstairs has amber light and won't work how do I fix it
Amber light on on sky mini upstairs and won't connect
