Discussion topic: Mini box says no satellite connection. Main box is fine , all status checks are fine
Message posted on 20 May 2025 10:11 PM
Mini box just is saying no satellite connection, but all the status checks are OK.... just hangs loading the content within the channels; the pictures on the Home Screen are there .... but you can't watch anything.
main box is fine .
rebooted everything, checked software up to date etc ...
any clue ?
Message posted on 20 May 2025 10:19 PM
Re: Mini box says no satellite connection. Main box is fine , all status checks are fine
@Xxkdnd wrote:
Mini box just is saying no satellite connection, but all the status checks are OK.... just hangs loading the content within the channels; the pictures on the Home Screen are there .... but you can't watch anything.main box is fine .
any clue ?
Hi @Xxkdnd
Try a Network Reset on the mini.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
Message posted on 21 May 2025 03:17 PM
Thank you
tried doing it , hasn't made a difference
i don't think i need a booster as it has been working fine for 5 years....
