Discussion topic: Mini box not connecting to my sky q box
Message posted on 07 Sep 2024 04:32 PM
As per title of post.
Message posted on 07 Sep 2024 04:50 PM
Re: Mini box not connecting to my sky q box
Hi @Geoff1007
Reboot the mini as above.
