Discussion topic: Mini box not connecting to main box via router
Message posted on 04 Aug 2024 10:05 AM
Hi my mini box keeks trying to connect to my router. I have gone through the steps of trying to reconnect but when screen says obtaining IP address it tells me there is a WiFi connectivity issue.
Message posted on 04 Aug 2024 10:25 AM
Re: Mini box not connecting to main box via router
Hi @Michael157
Reboot the mini as above.
