Discussion topic: Mini box not connecting after upgrading to fibre
Message posted on 29 Sep 2024 10:24 AM
Recently upgraded to fibre broadband mini box not holding connection upstairs will connect for a few minutes then drop connection. Would appreciate any help/advice.
Message posted on 29 Sep 2024 10:25 AM
Re: Mini box not connecting after upgrading to fibre
Hi @muscles79
Reboot the mini as above.
Message posted on 01 Oct 2024 07:50 AM
Thanks that worked!!
