Discussion topic: Mini box isn’t connecting to downstairs
This message was authored by: Topchef197350
My mini box won't connect to main box downstairs
This message was authored by: Greenfingers001
Re: Mini box isn’t connecting to downstairs
Hi there @Topchef197350 , I’ve escalated your post to our Community Messaging team who will invite you to a private chat shortly and help you with this.
This message was authored by: Addie15
Update-We are closing this invite now due to no response within 48 hours. If you still need help, please let us know so we can re-escalate this for you. Thanks.
Hi @Topchef197350
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box
