Discussion topic: Mini box is not working properly, freezing and jumping ahead, it is not a Wi-Fi issue
Message posted on 07 Aug 2024 01:55 PM
I have tried switching main box and mini box on and off a few times with no improvement
Message posted on 07 Aug 2024 02:01 PM
Re: Mini box is not working properly, freezing and jumping ahead, it is not a Wi-Fi issue
Hi @PaulJ26
Try a Network Reset on the mini.
