Discussion topic: Mini box is constantly losing connection between sky q which is working fine
Message posted on 24 Feb 2024 08:49 AM
Constantly dropping out. I get 10 seconds tv then it disconnects for 3-4 minutes then repeats.
q box works fine and I have repeatedly reverted both boxes and WiFi with no benefit
Message posted on 24 Feb 2024 08:55 AM
Re: Mini box is constantly losing connection between sky q which is working fine
Hi @raspberry in this order, try rebooting your router by removing the power cable for 30 sec then reconnect to reboot, then reboot your main SKYQ box by turning the power off at the socket for 30 sec then turn back on, then do the same with the Mini box?
