Discussion topic: Mini box has to be reactivated every time I switch it on
Message posted on 31 Jul 2024 07:31 PM
Message posted on 31 Jul 2024 08:31 PM
Re: Mini box has to be reactivated every time I switch it on
Hi @Simon1203
Assume you are putting the Mini in Standby and not switching it Off at the mains?
Try completely reconnecting the mini.
Reboot the mini as above.
