Discussion topic: Mini box can’t get up address after changing WiFi to sky fibre
This message was authored by: John+C+Owen
Changed WiFi to sky fibre 150MB and now mini box in kitchen can't connect to WiFi
Re: Mini box can’t get up address after changing WiFi to sky fibre
New white sky max router or no?
Avatar for John+C+Owen
Yes - brand new white sky max router
Hi @John+C+Owen
With the new Sky Max router you need to connect the Mini to the main Q box if using WiFi.
Reboot the mini as above.
