Discussion topic: Message on screen "connecting to your skq q box" with a spinning wheel - how do I connect??
Message posted on 06 Mar 2023 06:52 PM
My Sky Q box has stopped working.............. I have a sound but no picture and just a message saying "connecting to your sky Q box…" with a spinning wheel............. How do I clear this message and get back in?? I've tried switching off my Sky Q box and turning it back on again but still get the same message, i've also tried turning off my wifi (also Sky) and turning that back on again but am still getting the same message - anyone any ideas please? Thank you....
Message posted on 06 Mar 2023 07:03 PM - last edited: 06 Mar 2023 07:04 PM
Re: Message on screen "connecting to your skq q box" with a spinning wheel - how do I conn
Hi @Jemm27
Is this on a Sky Q mini?
Message posted on 06 Mar 2023 07:10 PM
Yes it is a mini box
Message posted on 06 Mar 2023 07:12 PM - last edited: 06 Mar 2023 07:13 PM
Hi @Jemm27
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box
Message posted on 06 Mar 2023 07:57 PM
Hi @oldfella ,
Thanks for that but unfort it didn't work when I unplugged the main Sky Q box......how exactly do I do the network reset on the mini box as when I click home on the remote & point at the box it doesn't show anything on the tv other than the message "connecting to your sky Q box" & the spinning wheel.....so i'm not sure how to do the network reset???? Thank you.......
Message posted on 06 Mar 2023 08:01 PM
@Jemm27 wrote:
Hi @oldfella ,
Hi @Jemm27
Try rebooting the mini again.
if you get the same message try pressing the WPS button on the main Q box
Message posted on 06 Mar 2023 10:02 PM
Hi @oldfella
Unfortunately that didn't work either, I still have the "connecting to your Sky Q Box" message on screen.......
Message posted on 06 Mar 2023 10:10 PM
@Jemm27 wrote:
Hi @oldfella
Ok @Jemm27
I assume your main TV has a spare HDMI input.
If it is possible move your mini and connect it to a spare HDMI input on your main TV.
Keep the main Q box connected normally and it needs to be at least in standby.
Select the mini HDMI on the TV and power up the mini. See if it will connect
Message posted on 07 Mar 2023 06:13 PM
@oldfella thanks for your help
Message posted on 07 Mar 2023 06:33 PM
Message posted on 07 Mar 2023 06:39 PM
@oldfella, not yet a Sky engineer is coming to reset, thanks for your help anyhow
Message posted on 11 Jan 2024 07:02 PM
Did you ever get this problem sorted.
I have 3 mini boxes.....2 are showing this blue screen and "connecting to your sky box" but nothing happens..
Message posted on 09 Apr 2024 10:47 PM
Currently having the same issue with one of my four mini boxes.
Have had this happen before and a power cycle of the mini box usually fixes it, but not this evening.
The other three mini boxes are operating fine, as is the main box.
Going to try a factory reset.
Message posted on 09 Apr 2024 10:53 PM
OK, factory reset worked. 👍
