Discussion topic: Max number of mini boxes in use
This message was authored by: SimonJake
This keeps happening more and more, I have 3 mini boxes and aware I can only use 2 at the same time plus main box. But I keep getting the max number of boxes in use when only one is and also sometimes when only the main box is on. I try restarting etc and still the same then next day ok but then all starts again, any ideas?
Re: Max number of mini boxes in use
Hi @SimonJake
Try a Reset Settings in the main Q box hidden menu.
Avatar for SimonJake
Level 2 icon
Back to square one again, only one mini on but on the other says max number of mini boxes in use, driving me mad!
This message was authored by: Sahotafam15
Max number of mini box in ise
@Sahotafam15
You perhaps need to tell us what is happening.
For your info you can have a maximum of 4 mini boxes loaned to you by Sky. You can watch Sky content on two minis and the main box at the same time. You may be able to use a 3rd mini box at the same time if you’re using it for one of the apps such as Netflix.
The original 1TB (non-UHD) Sky Q box only allows one mini to be in use. To check if you have the non UHD 1TB box check in:-
If it shows as 32Cxxx then you have a non UHD 1TB that only supports 1 active mini box.
All 2TBs and the UHD/HDR 1TB permit two mini boxes. Each mini box which is loaned to you may be subject to a one off upfront charge but you only need one Sky Q monthly Multiscreen subscription.
Level 2 icon
I have the one for 2 mini boxes and most of the time this works but every now and again the message of to many boxes in use pops up when only one on then you can turn the one that is on off then switch one of the the other on and all ok. This is random boxes so it can be any, it can go for days / weeks all ok then happen again and if switching them on and off then all ok in the morning (tv only really on at night).
@SimonJake
One tip is to always exit back to the Home screen after using an app and before putting a Mini on Standby: this seems to help the main Q box keep track of what's active.
Level 2 icon
Thanks for that i will give it a go,  think i will have to make some signs to stick next to the kids tv's to remnd them 🙂
