5
This discussion topic has been answered Discussion topic: Match result message showing whilst still watching recording
This message was authored by: PNG20
I often record football matches on sky sports and start watching them behind time while the match is still being played.
I've noticed quite a few times that I get a message in the bottom left corner of the screen that says "this match has now ended"......and gives the final result.
Obviously this spoils things if I then know the result before I've got to the end of the recorded match
Why does this happen and is there a way of switching this off?
This message was authored by: xenon81 Answer
Re: Match result message showing whilst still watching recording
Hi @PNG20
Only way to avoid this is to make sure that the Channel in question is not tuned to when you go to watch the recording.
Most of the Sport I watch is recorded and I make sure that if I'm putting  the Q box into standby I always first switch away from the channel that's being recorded.
That sounds like something generated by the TV rather than the Sky box. My LG has an option to display match results for specific teams (they also appear in the bottom left, is your TV LG too?). You would have to look through the TV menus to find the relevent settings to disable it.
This message was authored by: Doc5907
I believe @xenon81 is correct. Its certainly not a message generated by Sky Q so check your TV settings.
Sky Q 1TB UHD
LG TV
Sky Mobile
Avatar for PNG20
@xenon81 Yes I do have an LG TV. Thanks for the advice I'll check the TV menus
Here's some info on how to access the LG sports alert app:
https://www.lgtvguru.com/how-to-use-sports-alert-on-lg-smart-tv/
