Discussion topic: Main sky q box has no pause fast forward rewind record and can't access recordings
This message was authored by: Ton5
Main sky Q box has no fast forward rewind pause  or access to recordings. Keeps coming up on the screen you cannot pause or rewind.
Re: Main sky q box has no pause fast forward rewind record and can't access recordings
Hi @Ton5
Have you tried rebooting your Q box?
Avatar for Ton5
Thanks for your reply I have tried this but the problem still persists!
Looks like you may have a hard drive issue @Ton5  particulary if you also cannot make new recordings.
https://www.sky.com/help/articles/sky-q-hard-disk-error-messages
If you do have to order a new Q box this usually means a doorstep swap.
Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box. See below.
