Discussion topic: Main sky q box does not connect to wifi
This message was authored by: NH13
Have tried all steps in help guides and main q box and therefore mini boxes will not connect to wifi. This has owrsisted since yesterday morning. This is an issue two to three times a week but is usually resolved, although very annoying to have to keep doing it, by switching router off and on and reconnecting main box. Have done this repeatedly and followed all help steps for ovwr 24hours with no success
Re: Main sky q box does not connect to wifi
Hi @NH13
