Discussion topic: Main sky Q box working but 3 mini boxes all showing MR001 broadband connection showing good
Message posted on 13 Mar 2024 09:11 PM
Main sky box working as normal good connection 3 mini boxes all down showing MR001 error message.
i have turned them all off and on again followed various messages no luck this happened a few weeks ago
Message posted on 13 Mar 2024 09:21 PM
Re: Main sky Q box working but 3 mini boxes all showing MR001 broadband connection showing good
Hi @Gill70
Reboot the mini as above. Start with the mini nearest to the main Q box.
As you are on Sky Broadband if the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button.
When you carry out the Network reset on the second mini you can use the first mini for WPS if nearer than the main Q box. Follow the same procedure for other mini.
