Discussion topic: Main sky Q box recordings not working. Please wait displaying. Sky Q mini box TV guide not coming up
Message posted on 08 Jun 2023 12:31 PM
Can't watch Sky through sky mini box. Can watch Netflix through it. Displaying no satallite signal but in settings showing everything is connected?
Message posted on 08 Jun 2023 12:36 PM
Re: Main sky Q box recordings not working. Please wait displaying. Sky Q mini box TV guide not comin
Hi @Waterworks1
Reboot the mini as above.
You will be asked to press the WPS button on the main Q box (not the mini).
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box
Message posted on 08 Jun 2023 07:28 PM
@oldfella i have tried all of the above. The mini box is telling me no internet connection right now although everything is ticked in settings? Main Q box still no recordings showing?
Message posted on 08 Jun 2023 07:30 PM
Hi @Waterworks1
Can you make new recordings on the main Q box
Message posted on 08 Jun 2023 07:32 PM
no, saying problem with hard drive disk
Message posted on 08 Jun 2023 07:36 PM
Looks like a hard disk failure then @Waterworks1 .
Only thing you can try is a hard drive reset. Whatever happens you will lose all recordings.
Any purchased buy and keep content can be re downloaded to new Q box.
