Discussion topic: Main box noy connrting to intrrnet
Message posted on 13 Dec 2023 09:39 AM
My main box is not loading any apps. It is not connecting to my router
Message posted on 13 Dec 2023 09:52 AM
							Re: Main box noy connrting to intrrnet
Hi @Amanada
have you carried out a Network Reset on the main Q box?
Network reset found in Q box Home - Settings - Setup - Network.
Message posted on 13 Dec 2023 10:24 AM
It is not conneting to the internet, my lap top is in the same room as the sky q box and it is working.
Message posted on 13 Dec 2023 10:47 AM
Message posted on 13 Dec 2023 10:51 AM
It will not givw me an opption to carry out a network reboot.
Message posted on 13 Dec 2023 11:05 AM
Hi @Amanada
Exactly what do you see when you try Network Reset found in Q box Home - Settings - Setup - Network.
Message posted on 13 Dec 2023 11:13 AM
Once i try to connect with sky router it asked me to use a booster. When i try to connect by putting in wi-fi passward it says i am putting in an incorrct password.
Message posted on 13 Dec 2023 01:23 PM
Hi @Amanada
As I said in my post if you are on Sky Broadband then you use WPS not password.
Has it been connected to the internet previously?
