Discussion topic: Main box and mini box keep freezing and message appears on ‘ technical fault’
This message was authored by: PSR1
Screen keeps freezing on main box and mini box. Message appears. ' technical fault'   After about 6/7 minutes channel comes back. Any tips or fixes please?
Re: Main box and mini box keep freezing and message appears on ‘ technical fault’
Hi @PSR1 Try rebooting your router by removing the power cable for 30 sec then reconnect to reboot, then reboot your main SKYQ box by turning the power off at the socket for 30 sec then turn back on, do the same with any Mini boxes?
