Discussion topic: Main Sky Q won’t turn on and making loud noise
This message was authored by: Liddiman
Hi,
my sky box is turned on plugged in to power etc and showing power light as red but sounds like an aeroplane about to take off - it was that loud this morning when I woke up that I could hear it upstairs (TV and sky box down stairs in living room) - I can't get it to turn on at all to get a menu/settings on or to watch anything.  I've tried disconnecting from power and and restating  with no luck and also unplugging the box from the Ethernet cable.
any suggestions? Been offered a visit from an engineer in 17 days time 🤦🏻‍♂️
thanks
Re: Main Sky Q won’t turn on and making loud noise
Sounds like you need a new box.  Call them and ask for a box swap (Remember to remove your viewing card).
Avatar for Liddiman
Thanks @PandJ2020 for your response. I would have thought a new box is required too but they said I should wait for the engineering in 17 days time. Seems a long time with no ability to use the Main box or the mini box.
