Discussion topic: Main Sky Q box works, 2 x mini boxes won’t
Message posted on 04 Mar 2025 10:00 AM
If my sky Q box is working, how are my mini boxes not working?
Error code MR102.
thanks
Message posted on 04 Mar 2025 10:01 AM
Re: Main Sky Q box works, 2 x mini boxes won’t
They both used to work. I've had them for ages.
Message posted on 04 Mar 2025 10:19 AM
Error code MR102.
thanks
Hi @Jamhot note: some features may take up to 5 minutes to return.
First reboot your Q box.
Reboot the minis as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router if on Sky Broadband or previously connected mini).
