Discussion topic: MR204 and MR104 Sky Q Mini box error
Message posted on 17 Oct 2025 08:48 PM
I am having a nightmare getting my mini box connected to my main box. I have previously had a mini box so I am aware of the usual fixes, however this box is located in a different room in the house. Is it possible that we now need a booster? I have tried rebooting non sky router, main box and then mini box on a number of occasions but no success. The mini box has connected but then drops out or is just so slow that it's not possible to use it. Thanks in advance,
Message posted on 17 Oct 2025 08:53 PM
Re: MR204 and MR104 Sky Q Mini box error
Yes.
Message posted on 17 Oct 2025 09:00 PM
Hi @Ca1267
Have you carried out a Network reset on the mini?
Failing all of the above then you may need a Sky Q WiFi Booster to position midway between your main Q box and the mini and you will need to contact Sky directly.
Message posted on 17 Oct 2025 09:31 PM
Yes I have done the mini box reset a couple of times but no luck. I think the booster is possibly the solution. Thanks for replying.
