Discussion topic: Lost some of my tv channels
This message was authored by: ad1960
Have lost some but not all channel. Have attempted a reboot it without success. Have the same issue with my minibox as well as SkyQ
Re: Lost some of my tv channels
@ad1960
Are you seeing an error message?
Avatar for ad1960
No, just the banner indicating a problem with my satellite signal.
@ad1960
If a message displays “no satellite signal” firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s likely to be a dish alignment issue so check the troubleshooting in this link
If you are connected to a communal dish you need to liaise with your building management company / landlord who will have their approved engineers to contact.
Remember, a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
Start here: https://www.sky.com/help/articles/sky-tv-no-satellite-signal
Most likely is your dish is out of alignment.
Avatar for ad1960
Thanks, one of the aerial leads had pulled out. Unfortunately having difficulty in crimping the cable back in.  Definitely why I have the problem though.
In that case, would suggest requesting an engineer visit as linked on Sky help article tab three above or via link below;
https://www.sky.com/signin?area=mysky&successUrl=https%3A%2F%2Fwww.sky.com%2Fhelp%2Fbook-tv-engineer
