Discussion topic: Lost signal on some channels
This message was authored by: A911
Hi lately I've not received some channels as it says lost signal, I don't know if its the weather that as caused it or I've had some work done to the flat and I don't know if the satellite dish as been knocked
Re: Lost signal on some channels
@A911
If a message is displaying ”No signal” it tends to be from your TV not being on the correct input (check the HDMI cable between the Sky Q box and your TV)
Any “no satellite signal” message relates to your Sky box.
Whenever a “no satellite signal” message is displayed firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Also check out the troubleshooting on this link
It may then give you the opportunity to arrange an engineer to check the alignment of your dish.
A misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels. If you’re on a communal dish you may initially need to liaise with your landlord or building management company.
