Discussion topic: Lost picture, then remote failed, tried holding 7&9 then 1&3 still no response
Message posted on 06 Apr 2024 11:44 AM
Whilst watching sky football, lost picture, got it back after re setting, but kept going off, now gone completely & cannot even get message back to start up, remote has failed also having tried holding 7/9. 1/3 etc
Message posted on 06 Apr 2024 12:24 PM
Re: Lost picture, then remote failed, tried holding 7&9 then 1&3 still no response
Hi @Kevyn
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Try completely resetting your Bluetooth remote again.
With the Q box on with green led;
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
Message posted on 06 Apr 2024 12:29 PM
Same problem and still no TV. Q box is green.
Message posted on 06 Apr 2024 12:32 PM
Unplugged Q box and back in. Problem resolved.
